Philco 610B Tone Control 30-4318 caps
Go with to .003 and .02. That will give you a fair amount of difference between the two setting.
Re: Philco 610B Tone Control 30-4318 caps - by 7estatdef - 10-12-2011, 09:01 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7512 online users. [Complete List]
» 3 Member(s) | 7509 Guest(s)
