37-60B?
Good! The 37-61 is better than a 37-60 in that the 37-61 has a better SW band - 5.7 to 18.2 mc, as opposed to 2.3 to 7.4 mc on the 37-60. Plus, the 37-61 has two-speed tuning with dual concentric tuning knobs, which makes it easier to tune on the SW band.
Good luck.
37-60B? - by Dave - 09-04-2011, 09:44 PM
Re: 37-60B? - by Ron Ramirez - 09-04-2011, 10:23 PM
Re: 37-60B? - by Dave - 09-04-2011, 11:02 PM
Re: 37-60B? - by Ron Ramirez - 09-05-2011, 06:24 AM
Re: 37-60B? - by Dave - 09-05-2011, 02:11 PM
Re: 37-60B? - by Ron Ramirez - 09-05-2011, 02:21 PM
There are currently 10546 online users. [Complete List]
» 2 Member(s) | 10544 Guest(s)
