Philco 39-45 restoration: speaker wiring question and more
Thanks for your reply, Jimmy.
That sounds very possible.... maybe they tried to splice in the output of a phonograph? I'm guessing the top speaker terminal wire might go to the cut socket wire and the bottom speaker terminal wire goes to the wire hanging down from coil winding.
I'll wait to see what others say before trying this.... would hate to blow any transformers.
Re: Philco 39-45 restoration: speaker wiring question and mo - by greenskull - 09-05-2011, 08:13 PM
Users browsing this thread: 14 Guest(s)
The speaker table error?
Philco 70 antenna lead
