Philco 39-45 restoration: speaker wiring question and more
Ok if that is the case then what you will have is 4 wires coming out the the FC. Two of them come straight out of the FC. Those will go over the speaker plug. There maybe two other wires that come out right above the FC. Those go to the hum bucking coil. It's a separate coil NOT connected to the field coil. The HBC is connected to one side of the voice coil and the other goes to the output transformer. (it's in series with voice coil)
Re: Philco 39-45 restoration: speaker wiring question and mo - by 7estatdef - 09-05-2011, 09:24 PM
The speaker table error?
Philco 70 antenna lead
