Philco 38-17F Variant - another undocumented set
#36
I'm also troubled by the eBay rating system. I recently won and paid for a Model 60B (late version). Soon thereafter the seller began making excuses why he had not shipped my radio. I gave him plenty of opportunity to make things right. He then stopped replying to my emails. I reported the incident after 40 days and eBay refunded my money (Buyer Protection). The seller also stiffed several other buyers at about the same time. Here's the rub; the seller still has a rating of 98.2%. This is because he had many good ratings before he went on his crime spree. My search for a Model 60B continues.
Re: Philco 38-17F Variant - another undocumented set - by Allen in SB - 09-06-2011, 12:15 AM
There are currently 8732 online users. [Complete List]
» 2 Member(s) | 8730 Guest(s)
