Canadian Philco 334
Thank you for the information about the Grimes line of radios. Mine is a Serenader. Interesting that they built models for sale by different retail stores like Colonial did for Sears, etc......
On the schematic the Phenola, Serenader, Viking, Minerva, and Arcadia brand names are listed. Now it makes more sense.
Canadian Philco 334 - by TA Forbes - 08-20-2011, 10:07 PM
Re: Canadian Philco 334 - by Arran - 09-06-2011, 12:50 AM
Re: Canadian Philco 334 - by TA Forbes - 09-06-2011, 01:39 AM
Re: Canadian Philco 334 - by Arran - 09-07-2011, 09:21 PM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 12:04 AM
Re: Canadian Philco 334 - by Arran - 09-08-2011, 12:13 AM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 12:51 AM
Re: Canadian Philco 334 - by Arran - 09-08-2011, 07:04 PM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 10:56 PM
Re: Canadian Philco 334 - by Arran - 09-09-2011, 12:50 AM
Re: Canadian Philco 334 - by Eliot Ness - 09-09-2011, 10:25 AM
Re: Canadian Philco 334 - by TA Forbes - 09-09-2011, 09:09 PM
Re: Canadian Philco 334 - by Ron Ramirez - 09-09-2011, 09:26 PM
Re: Canadian Philco 334 - by TA Forbes - 09-10-2011, 12:59 PM
Re: Canadian Philco 334 - by Arran - 09-10-2011, 09:27 PM
Re: Canadian Philco 334 - by Arran - 09-10-2011, 09:49 PM
Re: Canadian Philco 334 - by TA Forbes - 09-10-2011, 10:32 PM
There are currently 9517 online users. [Complete List]
» 6 Member(s) | 9511 Guest(s)
AvatarAvatarAvatarAvatar
