My Hershey car show prize!
I like these style stands for radios. Sort of like creating a skeletal console when you use these stands with the radios and speakers. I have seen similar stands for Atwater-Kent radios, but this is the first with a Philco on it that I have seen.
My Hershey car show prize! - by 37silverstreak - 10-08-2011, 08:22 PM
Re: My Hershey car show prize! - by TA Forbes - 10-08-2011, 10:30 PM
Re: My Hershey car show prize! - by Ron Ramirez - 10-09-2011, 08:41 AM
Re: My Hershey car show prize! - by Marsupial - 10-09-2011, 09:32 AM
Re: My Hershey car show prize! - by Ron Ramirez - 10-09-2011, 02:15 PM
Re: My Hershey car show prize! - by Chicago Jimmy - 10-09-2011, 02:20 PM
Re: My Hershey car show prize! - by Marsupial - 10-09-2011, 09:12 PM
Re: My Hershey car show prize! - by Doug Houston - 10-09-2011, 11:48 PM
Re: My Hershey car show prize! - by Marsupial - 10-10-2011, 01:44 AM
Re: My Hershey car show prize! - by Glenn Roberts - 10-10-2011, 01:35 PM
Re: My Hershey car show prize! - by Texasrocker - 10-10-2011, 01:50 PM
Re: My Hershey car show prize! - by TA Forbes - 10-10-2011, 08:13 PM
Re: My Hershey car show prize! - by Jayce - 10-11-2011, 08:36 PM
Re: My Hershey car show prize! - by PhilcoMike - 10-19-2011, 01:44 PM
There are currently 9686 online users. [Complete List]
» 1 Member(s) | 9685 Guest(s)
