Canadian Philco 334
Thank you! The cabinet was pretty rough when I got it, I referred to the site for the 3118 resto for color, but from what I could tell the two stripes on the bottom of my 334 were separately dark, not like the 3118.
Canadian Philco 334 - by TA Forbes - 08-20-2011, 10:07 PM
Re: Canadian Philco 334 - by Arran - 09-06-2011, 12:50 AM
Re: Canadian Philco 334 - by TA Forbes - 09-06-2011, 01:39 AM
Re: Canadian Philco 334 - by Arran - 09-07-2011, 09:21 PM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 12:04 AM
Re: Canadian Philco 334 - by Arran - 09-08-2011, 12:13 AM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 12:51 AM
Re: Canadian Philco 334 - by Arran - 09-08-2011, 07:04 PM
Re: Canadian Philco 334 - by TA Forbes - 09-08-2011, 10:56 PM
Re: Canadian Philco 334 - by Arran - 09-09-2011, 12:50 AM
Re: Canadian Philco 334 - by Eliot Ness - 09-09-2011, 10:25 AM
Re: Canadian Philco 334 - by TA Forbes - 09-09-2011, 09:09 PM
Re: Canadian Philco 334 - by Ron Ramirez - 09-09-2011, 09:26 PM
Re: Canadian Philco 334 - by TA Forbes - 09-10-2011, 12:59 PM
Re: Canadian Philco 334 - by Arran - 09-10-2011, 09:27 PM
Re: Canadian Philco 334 - by Arran - 09-10-2011, 09:49 PM
Re: Canadian Philco 334 - by TA Forbes - 09-10-2011, 10:32 PM
There are currently 6102 online users. [Complete List]
» 4 Member(s) | 6098 Guest(s)
AvatarAvatarAvatarAvatar
