Need Grille cloth help
In that case, I am afraid you are out of luck. The final version of the 60B takes the Philco "Ribbed" cloth (#14), and neither John or Radio Daze have this any longer. Not sure about AES.
Need Grille cloth help - by 7estatdef - 08-22-2011, 03:37 PM
Re: Need Grille cloth help - by Ron Ramirez - 08-22-2011, 03:55 PM
Re: Need Grille cloth help - by 7estatdef - 08-22-2011, 04:37 PM
Re: Need Grille cloth help - by Ron Ramirez - 08-22-2011, 06:05 PM
Re: Need Grille cloth help - by SamTanner - 09-14-2011, 04:03 PM
Re: Need Grille cloth help - by Ron Ramirez - 09-14-2011, 10:26 PM
Re: Need Grille cloth help - by SamTanner - 09-14-2011, 10:36 PM
Re: Need Grille cloth help - by Ron Ramirez - 09-14-2011, 10:40 PM
Re: Need Grille cloth help - by Arran - 09-15-2011, 07:47 PM
There are currently 11388 online users. [Complete List]
» 2 Member(s) | 11386 Guest(s)
