Philco model 42-1012 power problem
Ron Ramirez Wrote:Murf, if you're still here, I see you are advertising for another chassis now.
Before you give up...did you try cleaning the power switch as Sean suggested?
Sure did.Used radio shack
cleaner.
Re-built the bakelight block cap tonight just for grins.No change.
Got to be the tranny.
Chassis available from one of our guy's for $25 plus shipping,but it is untested other than the tranny works.
If he tried it using a variac,that would be safe wouldn't it?
Thanks Ron,this is a very helpful website.Keep up the good work.
murf
Philco model 42-1012 power problem - by murf - 09-08-2011, 08:17 AM
Re: Philco model 42-1012 power problem - by Sean - 09-08-2011, 08:37 AM
Re: Philco model 42-1012 power problem - by gvel - 09-08-2011, 07:10 PM
Re: Philco model 42-1012 power problem - by murf - 09-08-2011, 08:46 PM
Re: Philco model 42-1012 power problem - by gvel - 09-09-2011, 09:13 AM
Re: Philco model 42-1012 power problem - by murf - 09-09-2011, 07:14 PM
Re: Philco model 42-1012 power problem - by murf - 09-09-2011, 10:40 PM
Re: Philco model 42-1012 power problem - by Sean - 09-10-2011, 09:57 AM
Re: Philco model 42-1012 power problem - by murf - 09-10-2011, 11:02 AM
Re: Philco model 42-1012 power problem - by murf - 09-10-2011, 11:59 AM
Re: Philco model 42-1012 power problem - by Sean - 09-10-2011, 08:44 PM
Re: Philco model 42-1012 power problem - by murf - 09-14-2011, 10:48 PM
Re: Philco model 42-1012 power problem - by Arran - 09-16-2011, 01:24 AM
Re: Philco model 42-1012 power problem - by murf - 09-16-2011, 07:05 AM
Re: Philco model 42-1012 power problem - by murf - 09-22-2011, 08:33 PM
Re: Philco model 42-1012 power problem - by murf - 09-22-2011, 11:00 PM
91H Code 126 Restore
Philco 70 antenna lead
