40-180 buttons needed
Yes, that's the piece I was talking about. One end is held on just by a staple or two. How solid do they need to be to be effective?
Ryan
40-180 buttons needed - by OzRadio - 08-09-2006, 07:53 AM
[No subject] - by Sean - 08-09-2006, 08:08 AM
[No subject] - by Carl Travis - 08-09-2006, 02:05 PM
[No subject] - by OzRadio - 08-10-2006, 07:28 PM
[No subject] - by gary rabbitt - 09-28-2006, 07:01 PM
There are currently 4511 online users. [Complete List]
» 1 Member(s) | 4510 Guest(s)
