Philco 39-45 restoration: speaker wiring question and more
Alright, getting ready to order parts, but first have a quick question regarding sleeving the wires coming out of the power transformer (rubber dry rotted):
Is heat shrink tubing okay for this or should I get some of that fiberglass spaghetti tubing?
Thank you!
Re: Philco 39-45 restoration: speaker wiring question and mo - by greenskull - 09-16-2011, 07:01 PM
The speaker table error?
Philco 70 antenna lead
