Philco 40-180 Dial Lamp??
Hello all,
I'm new to the forum, but not new to old radios... I'm currently working on a 40-180 that I picked up a few weeks ago at a garage sale. I'm wondering what the correct dial lamp is for this model. The lamp I found in the radio when I got it was a Tung-Sol LM27. I'm not sure what it crosses to. Can anyone help me out?
Thanks!
Brian
Philco 40-180 Dial Lamp?? - by w8khz - 09-17-2011, 10:54 PM
Re: Philco 40-180 Dial Lamp?? - by Ron Ramirez - 09-18-2011, 07:09 AM
Re: Philco 40-180 Dial Lamp?? - by Chicago Jimmy - 09-18-2011, 07:18 AM
Re: Philco 40-180 Dial Lamp?? - by Ron Ramirez - 09-18-2011, 07:27 AM
There are currently 8846 online users. [Complete List]
» 3 Member(s) | 8843 Guest(s)
