Philco 40-180 Dial Lamp??
Brian, First... welcome to the Phorum!
The philco part # 34-2210 is a frosted bulb and 6-8 volts. You can use a #44 bulb. It's clear,but it has the same bayonet base and volts/ma.
Ron, Your up early...while I was looking this up...you slipped in the reply. Icon_lol
Philco 40-180 Dial Lamp?? - by w8khz - 09-17-2011, 10:54 PM
Re: Philco 40-180 Dial Lamp?? - by Ron Ramirez - 09-18-2011, 07:09 AM
Re: Philco 40-180 Dial Lamp?? - by Chicago Jimmy - 09-18-2011, 07:18 AM
Re: Philco 40-180 Dial Lamp?? - by Ron Ramirez - 09-18-2011, 07:27 AM
There are currently 8717 online users. [Complete List]
» 2 Member(s) | 8715 Guest(s)
