116x Rectifier light show
The caps are MIEC brand purchased from Dave at just radios. The values are 10uf 450 volts. I have used these same caps in probably 10 radios with no issues. The caps I put in the radio last night were 20uf because I used up all the 10uf I had on hand. Needed to get caps in the radio to check voltages.
116x Rectifier light show - by garyh1 - 09-13-2011, 11:50 PM
Re: 116x Rectifier light show - by codefox1 - 09-14-2011, 09:10 AM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 10:32 AM
Re: 116x Rectifier light show - by TA Forbes - 09-17-2011, 12:25 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:16 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:38 PM
Re: 116x Rectifier light show - by Marsupial - 09-18-2011, 01:07 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 01:29 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:04 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:06 AM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 07:05 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 11:41 AM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 04:55 PM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 04:56 PM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 07:03 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-19-2011, 02:35 AM
Re: 116x Rectifier light show - by Glenn Roberts - 09-19-2011, 04:15 AM
Re: 116x Rectifier light show - by codefox1 - 09-19-2011, 10:43 AM
Re: 116x Rectifier light show - by garyh1 - 09-19-2011, 01:29 PM
Re: 116x Rectifier light show - by TA Forbes - 09-19-2011, 01:53 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-20-2011, 12:18 AM
91H Code 126 Restore
Philco 70 antenna lead
