Philco 46-350 Battery Build
Terry,
I appreciate the tip, but I've already replaced all the old capacitors. Still working on a housing for the battery, I'll update you guys as soon as I finish it up.
Russ
Philco 46-350 Battery Build - by subwyking - 09-08-2011, 09:48 AM
Re: Philco 46-350 Battery Build - by BILL - 09-08-2011, 03:26 PM
Re: Philco 46-350 Battery Build - by subwyking - 09-08-2011, 06:30 PM
Re: Philco 46-350 Battery Build - by codefox1 - 09-08-2011, 10:19 PM
Re: Philco 46-350 Battery Build - by subwyking - 09-11-2011, 06:06 PM
Re: Philco 46-350 Battery Build - by subwyking - 09-11-2011, 06:12 PM
Re: Philco 46-350 Battery Build - by John R - 09-11-2011, 08:32 PM
Re: Philco 46-350 Battery Build - by codefox1 - 09-11-2011, 09:52 PM
Re: Philco 46-350 Battery Build - by subwyking - 09-11-2011, 10:45 PM
Re: Philco 46-350 Battery Build - by John R - 09-12-2011, 12:41 AM
Re: Philco 46-350 Battery Build - by BILL - 09-12-2011, 09:37 AM
Re: Philco 46-350 Battery Build - by subwyking - 09-12-2011, 11:50 AM
Re: Philco 46-350 Battery Build - by 7estatdef - 09-12-2011, 02:02 PM
Re: Philco 46-350 Battery Build - by subwyking - 09-18-2011, 04:57 PM
There are currently 9612 online users. [Complete List]
» 2 Member(s) | 9610 Guest(s)
