116x Rectifier light show
A bucking transformer is a good idea on these sets. I have one in my 16B and have used it for many,many hours with no problems. I also added a CL-90 thermistor on one side of the AC line to prevent current surges at start up. Getting the AC line voltage down to around 105-110 VAC is a good idea and will not change the performance of the set at all. Check your voltages at startup on the capacitor that is having problems with the rectifier installed.
116x Rectifier light show - by garyh1 - 09-13-2011, 11:50 PM
Re: 116x Rectifier light show - by codefox1 - 09-14-2011, 09:10 AM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 10:32 AM
Re: 116x Rectifier light show - by TA Forbes - 09-17-2011, 12:25 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:16 PM
Re: 116x Rectifier light show - by garyh1 - 09-17-2011, 07:38 PM
Re: 116x Rectifier light show - by Marsupial - 09-18-2011, 01:07 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 01:29 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:04 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 03:06 AM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 07:05 AM
Re: 116x Rectifier light show - by garyh1 - 09-18-2011, 11:41 AM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 04:55 PM
Re: 116x Rectifier light show - by Ron Ramirez - 09-18-2011, 04:56 PM
Re: 116x Rectifier light show - by TA Forbes - 09-18-2011, 07:03 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-19-2011, 02:35 AM
Re: 116x Rectifier light show - by Glenn Roberts - 09-19-2011, 04:15 AM
Re: 116x Rectifier light show - by codefox1 - 09-19-2011, 10:43 AM
Re: 116x Rectifier light show - by garyh1 - 09-19-2011, 01:29 PM
Re: 116x Rectifier light show - by TA Forbes - 09-19-2011, 01:53 PM
Re: 116x Rectifier light show - by thirtiesradio - 09-20-2011, 12:18 AM
The speaker table error?
Philco 70 antenna lead
