That looks a model 84 from the tubes in it 37-84 would use octal tubes
vinzer
37-84 - by 7estatdef - 09-20-2011, 12:35 PM
Re: 37-84 - by Ron Ramirez - 09-20-2011, 12:55 PM
Re: 37-84 - by vinzer - 09-20-2011, 02:03 PM
Re: 37-84 - by 7estatdef - 09-20-2011, 03:39 PM
There are currently 4544 online users. [Complete List]
» 3 Member(s) | 4541 Guest(s)
