beam of Light changer adjustments
Your 1941 model has a changer part number of 35-1233, gear drive type. The ten-page service bulletin is part of my service info packet that normally comes with the model 41-609 and 41-609, which both used that changer. I also have the service info on the cutter head/arm called the HR-1 Home Recording Unit.
See the Schematic Info page on my site to order.
Regards,
Chuck Schwark
beam of Light changer adjustments - by davidff - 09-20-2011, 02:21 PM
Re: beam of Light changer adjustments - by Chuck Schwark - 09-20-2011, 03:52 PM
Re: beam of Light changer adjustments - by Sean - 09-21-2011, 09:23 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7099 online users. [Complete List]
» 1 Member(s) | 7098 Guest(s)
