16B question
Hi,
Yes, that is the correct chassis for that cabinet. Go for it...and good luck!
16B question - by thirtiesradio - 09-22-2011, 06:15 PM
Re: 16B question - by Ron Ramirez - 09-22-2011, 07:53 PM
Re: 16B question - by Marsupial - 09-22-2011, 09:26 PM
Re: 16B question - by thirtiesradio - 09-22-2011, 10:09 PM
Re: 16B question - by TA Forbes - 09-23-2011, 09:55 PM
Re: 16B question - by thirtiesradio - 09-24-2011, 05:02 PM
Re: 16B question - by Allen in SB - 09-30-2011, 09:14 PM
Re: 16B question - by thirtiesradio - 09-30-2011, 11:05 PM
Re: 16B question - by Arran - 10-18-2011, 01:39 AM
Re: 16B question - by thirtiesradio - 10-21-2011, 11:06 PM
There are currently 9964 online users. [Complete List]
» 2 Member(s) | 9962 Guest(s)
