40-180 Antenna Disassembly
I picked up an excellent condition 40-180 a couple of months ago and of course the rubber wiring is shot. I've rebuilt the chassis and now need to work on the antenna. Is there a way to disassemble the paper coated antenna without destroying it in the process? As expected, the paper is brittle but not to badly. Any advice?
Chris
KD7WMZ
Visit Chris' Old Radios and Precision Tube Testers
http://oldradios.50webs.com/index.html
40-180 Antenna Disassembly - by cgholly - 09-22-2011, 08:50 PM
Re: 40-180 Antenna Disassembly - by Ron Ramirez - 09-23-2011, 07:18 AM
Re: 40-180 Antenna Disassembly - by cgholly - 09-23-2011, 03:01 PM
The speaker table error?
Philco 70 antenna lead
