Philco 38-7 CS restoration
Threads: 42
City: Chicago, IL
I finally have the sides prepped for toner. I'm doing the front first then the back. I find it hard to get an even coat over a large cabinet when working with just a spray can.
[Image: http://farm7.static.flickr.com/6159/6176...0d21_z.jpg]
It's amazing what a little toner will do
[Image: http://farm7.static.flickr.com/6155/6175...5967_z.jpg]
Re: Philco 38-7 CS restoration - by Bob Andersen - 09-23-2011, 05:47 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
