My Philco 16B
Nice 16B! I have a shouldered 16B just like yours, I just completed the process of refinishing it a couple days ago. I made the top and sides darker than I should have; I need to invest in some of Mohawk's "Ultra Classic" toner which has dye instead of pigment. Still, it looks a lot better than it did when I bought it. I managed to save the original PHILCO decal, too.
My Philco 16B - by thirtiesradio - 09-23-2011, 01:45 AM
Re: My Philco 16B - by Glenn Roberts - 09-23-2011, 04:07 AM
Re: My Philco 16B - by thirtiesradio - 09-23-2011, 03:02 PM
Re: My Philco 16B - by Ron Ramirez - 09-23-2011, 08:01 PM
Re: My Philco 16B - by TA Forbes - 09-23-2011, 09:44 PM
Re: My Philco 16B - by thirtiesradio - 09-24-2011, 04:50 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 01:57 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 03:06 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 03:48 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 05:22 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 05:53 PM
Re: My Philco 16B - by Arran - 09-25-2011, 08:11 PM
Re: My Philco 16B - by Marsupial - 09-25-2011, 10:08 PM
Re: My Philco 16B - by Doug Houston - 09-28-2011, 11:17 PM
Re: My Philco 16B - by codefox1 - 09-29-2011, 09:38 AM
Re: My Philco 16B - by Steve Davis - 09-29-2011, 10:47 PM
Re: My Philco 16B - by Arran - 09-30-2011, 01:40 AM
There are currently 10052 online users. [Complete List]
» 1 Member(s) | 10051 Guest(s)
