advice on cabnit refinish
Complete novice at cabinet restoring.I am converting this 46-1213 radio cabinet into a tv stand.The electronics fit perfectly where the old phono went,and the smaller door on the right is ideal for a gaming system.Its a present for my brother.It doesn't have to be perfect but i would like to make it as nice as i can.Where do i start.Any and all advice would be greatly appreciated!!Thanks can't seem to upload pic,it keeps saying too big.I would gladly send a private email to one of you experts.
advice on cabnit refinish - by kelly - 09-24-2011, 12:26 PM
Re: advice on cabnit refinish - by Arran - 10-05-2011, 12:24 AM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 08:54 AM
Re: advice on cabnit refinish - by kelly - 10-05-2011, 11:50 AM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 01:18 PM
Re: advice on cabnit refinish - by ipwizard - 10-05-2011, 03:45 PM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 10:23 PM
There are currently 11364 online users. [Complete List]
» 2 Member(s) | 11362 Guest(s)
