Philco 144B
Arran Wrote:The 25 cycle sets usually had larger value filter capacitors and possibly a larger filter choke but the rest of the parts were the same.
Except for the power transformer. A transformer designed for 60 cycle operation will burn up at 25 cycles. However, a transformer designed for 25 cycles runs fine on 60 cycles.
Philco 144B - by thirtiesradio - 09-23-2011, 01:22 AM
Re: Philco 144B - by Ron Ramirez - 09-23-2011, 08:05 PM
Re: Philco 144B - by thirtiesradio - 09-25-2011, 12:39 AM
Re: Philco 144B - by Arran - 09-25-2011, 01:18 AM
Re: Philco 144B - by Ron Ramirez - 09-25-2011, 01:47 PM
Re: Philco 144B - by Arran - 09-27-2011, 12:37 AM
