38-116 Getting Working or Complete Restoration??
Terry,
Thanks for reply and info. I already printed out the schematic but ordered one from PhilcoRadio.com as well. I will also order the Cap kit later this week. Like I said it will be a winter project.....I also found the knobs I needed....I think finding a back cover will probably be more difficult if not impossible...
38-116 Getting Working or Complete Restoration?? - by Guest - 08-20-2006, 09:18 AM
[No subject] - by Terry Judkins - 08-20-2006, 11:20 PM
[No subject] - by Guest - 08-21-2006, 08:04 PM
5X4 position - by AI2V - 08-22-2006, 10:05 AM
[No subject] - by Guest - 08-22-2006, 07:24 PM
