Congrats to Ron for including the 1950s Philcos!
Thank you, glad you enjoy the new pages. Yes, when I gave this website a complete makeover early this year, I expanded the Gallery to include 1949 through 1960 models to reflect collector interest in these later Philco sets.
Re: Congrats to Ron for including the 1950s Philcos! - by Ron Ramirez - 09-25-2011, 09:32 PM
There are currently 8506 online users. [Complete List]
» 1 Member(s) | 8505 Guest(s)
