My Philco 16B
Ron Ramirez Wrote:I just barely put the chemicals over the PHILCO decal, expecting it to melt away. I was very happy when it didn't! So that portion of the finish is sort of original, with new lacquer over the top of it.
Is there a known working ethod to purposely protect vintage decals when they are good but the radio needs refinish?
I am thinking they did a good job on placing the logo on an exposed but not easily damaged area and most radios needing refinish might have a still good logo decal. In any case, mine it. It would be a shame to replace a perfect logo with sub-par replica just because somewhere else on the radio isn't in great shape.
-Mars
My Philco 16B - by thirtiesradio - 09-23-2011, 01:45 AM
Re: My Philco 16B - by Glenn Roberts - 09-23-2011, 04:07 AM
Re: My Philco 16B - by thirtiesradio - 09-23-2011, 03:02 PM
Re: My Philco 16B - by Ron Ramirez - 09-23-2011, 08:01 PM
Re: My Philco 16B - by TA Forbes - 09-23-2011, 09:44 PM
Re: My Philco 16B - by thirtiesradio - 09-24-2011, 04:50 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 01:57 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 03:06 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 03:48 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 05:22 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 05:53 PM
Re: My Philco 16B - by Arran - 09-25-2011, 08:11 PM
Re: My Philco 16B - by Marsupial - 09-25-2011, 10:08 PM
Re: My Philco 16B - by Doug Houston - 09-28-2011, 11:17 PM
Re: My Philco 16B - by codefox1 - 09-29-2011, 09:38 AM
Re: My Philco 16B - by Steve Davis - 09-29-2011, 10:47 PM
Re: My Philco 16B - by Arran - 09-30-2011, 01:40 AM
There are currently 9383 online users. [Complete List]
» 1 Member(s) | 9382 Guest(s)
