Cosmetic Restoration
I recently inherited a Model 90, 1-47 tube output, S/N 259927 in very good condition. However, I would like to do a cosmetic restoration and replace the following items to make it as original as possible.
Grille cloth: should I use the #1 whiskey or #2 copper hue still available at Radio Daze
Tubes: should all the tubes be globe/balloon or can ST's be used
Power cord: material, gauge, color, length and correct plug
Speaker wire: material, gauge and colors
Thank you in advance for your help.
Cosmetic Restoration - by Timothy - 09-26-2011, 01:31 PM
Re: Cosmetic Restoration - by Ron Ramirez - 09-28-2011, 01:37 PM
Re: Cosmetic Restoration - by Timothy - 10-03-2011, 03:12 PM
