Should I or should I not
I think It looks great the way it is. I always thought an item was worth more in it's original state, yet I go on the bay and radio's that are given freakish Steinway finishes are fetching good money....go figure....
Should I or should I not - by w4rtc - 09-26-2011, 06:27 PM
Re: Should I or should I not - by Dave - 09-26-2011, 06:45 PM
Re: Should I or should I not - by PHILLYPHILCO - 09-26-2011, 07:18 PM
Re: Should I or should I not - by 37silverstreak - 09-26-2011, 08:55 PM
Re: Should I or should I not - by Ron Ramirez - 09-26-2011, 09:07 PM
Re: Should I or should I not - by Paul Philco322 - 09-26-2011, 09:51 PM
Re: Should I or should I not - by TA Forbes - 09-26-2011, 09:59 PM
Re: Should I or should I not - by Chuck Schwark - 09-27-2011, 09:28 AM
Re: Should I or should I not - by AI2V - 09-30-2011, 09:27 AM
Re: Should I or should I not - by DeckApe - 09-30-2011, 01:57 PM
Re: Should I or should I not - by w4rtc - 09-30-2011, 03:12 PM
There are currently 10440 online users. [Complete List]
» 2 Member(s) | 10438 Guest(s)
