Joe's Maggie
w4rtc Wrote:I will have to face the fact that I cannot refinsh cabinets.
Sure you can! Looks OK to me. And if you can still see the woodgrain, then you did alright.
Refinishing is not an easy process. Like you, I felt that I could not refinish cabinets. I've sprayed lacquer on cabinets before, but they always ended up looking like an amateur refinish job because I was not using grain filler, and did not have the technique of sanding between so many coats down pat yet. So after many tries, failures, and poor results, I came to the conclusion that I should stick to chassis work and leave the cabinets to others.
But this year, I determined that I was going to learn how to properly refinish cabinets. My first efforts with using grain filler and sanding between coats turned out OK (Philco 38-14 and 39-7). A Philco 40-155 was a setback, it did not turn out as well as the first two. But after that, my technique gradually began to improve. I refinished a Philco 40-125 and it came out great. I moved on to an Atwater Kent 33, and it doesn't look bad at all. Next up, I refinished a Philco 16B shouldered tombstone, and it turned out even better. My latest project, which I finished this morning, is a Philco 53C cigar box pee-wee...and it was a wreck when I began. Now, I think I have finally achieved a good piano finish with this one.
I suggest you practice on small wood table model radios, and gradually work your way up to larger sets. If I can do this...you can, too.
Joe's Maggie - by w4rtc - 03-27-2011, 12:14 AM
RE: Joe's Maggie - by ipwizard - 03-02-2012, 05:16 PM
Re: Joe's Maggie - by Doug Houston - 03-27-2011, 08:38 PM
Re: Joe's Maggie - by w4rtc - 03-30-2011, 11:59 AM
Re: Joe's Maggie - by codefox1 - 03-30-2011, 01:47 PM
Re: Joe's Maggie - by Ron Ramirez - 03-31-2011, 07:44 PM
Re: Joe's Maggie - by Steve Davis - 03-31-2011, 09:14 PM
Re: Joe's Maggie - by w4rtc - 04-07-2011, 02:31 PM
Re: Joe's Maggie - by w4rtc - 04-12-2011, 12:54 PM
Re: Joe's Maggie - by Ron Ramirez - 04-12-2011, 01:10 PM
Re: Joe's Maggie - by Doug Houston - 04-12-2011, 11:35 PM
Re: Joe's Maggie - by Arran - 04-13-2011, 08:29 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 01:37 PM
Re: Joe's Maggie - by codefox1 - 05-08-2011, 03:59 PM
Re: Joe's Maggie - by Steve Davis - 05-08-2011, 05:04 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 05:07 PM
Re: Joe's Maggie - by w4rtc - 05-08-2011, 05:12 PM
Re: Joe's Maggie - by w4rtc - 05-09-2011, 04:01 PM
Re: Joe's Maggie - by w4rtc - 05-11-2011, 08:03 PM
Re: Joe's Maggie - by Ron Ramirez - 05-11-2011, 08:13 PM
Re: Joe's Maggie - by w4rtc - 09-26-2011, 08:34 PM
Re: Joe's Maggie - by Ron Ramirez - 09-26-2011, 09:01 PM
Re: Joe's Maggie - by w4rtc - 02-15-2012, 11:49 PM
Re: Joe's Maggie - by codefox1 - 02-16-2012, 10:09 AM
Re: Joe's Maggie - by Ron Ramirez - 02-16-2012, 05:20 PM
There are currently 10530 online users. [Complete List]
» 2 Member(s) | 10528 Guest(s)
