Philco 40-180 brought back to life... and an introduction...
Thanks for the welcome everyone! I'll be sticking around here for awhile. Hopefully I'll run across another restoration project soon. I have a line on a model 111 highboy in decent shape locally but not sure I want to go after it. I prefer big old radios that receive shortwave. You never know, I'm still considering it.
Brian
There are currently 8744 online users. [Complete List]
» 3 Member(s) | 8741 Guest(s)
