Philco 40-180 brought back to life... and an introduction...
Let me add my "welcome," too, Brian. Your 40-180 looks very nice! And don't be afraid of a model 111. It may be AM only, but man, what a radio...11 tubes and great performance.
There are currently 10611 online users. [Complete List]
» 3 Member(s) | 10608 Guest(s)
