Philco 42-380 Tuner
This seems to be a strange question to ask, but ...
Although I see the tuner indicator moving when I turn the tuning knob, the AM station
does not change from that landed on with the preset button. The tuning knob does, however, change the frequency when using the short wave radio.
Should the tuning knob when turned change the AM station as I expect of
other radios? Assuming yes, any idea why it is not doing so?
Philco 42-380 Tuner - by Brad L - 09-29-2011, 03:12 PM
Re: Philco 42-380 Tuner - by rghines1 - 09-30-2011, 09:15 AM
Re: Philco 42-380 Tuner - by codefox1 - 09-30-2011, 10:52 AM
Re: Philco 42-380 Tuner - by Ron Ramirez - 09-30-2011, 11:20 AM
There are currently 9102 online users. [Complete List]
» 1 Member(s) | 9101 Guest(s)
