My Philco 16B
codefox1 Wrote:Oh, I so want to try that out. I still have a stash of rapidly deteriorating artist pigments, must be 50+ years old which I pick out and dilute with linseed oil and paint thinner to fix up flaws and paint in patches with a couple of tiny "spotting" brushes left over from the film era when I still had decent eyesight. Anyway, of the hue, value, and chroma, surprisingly the value is most important (roughly speaking grey scale.)
That might work with alkyd varnish but I wonder if they would mix into laquer or thin with laquer thinner if they are normally diluted with linseed oil or mineral spirits?
My Philco 16B - by thirtiesradio - 09-23-2011, 01:45 AM
Re: My Philco 16B - by Glenn Roberts - 09-23-2011, 04:07 AM
Re: My Philco 16B - by thirtiesradio - 09-23-2011, 03:02 PM
Re: My Philco 16B - by Ron Ramirez - 09-23-2011, 08:01 PM
Re: My Philco 16B - by TA Forbes - 09-23-2011, 09:44 PM
Re: My Philco 16B - by thirtiesradio - 09-24-2011, 04:50 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 01:57 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 03:06 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 03:48 PM
Re: My Philco 16B - by thirtiesradio - 09-25-2011, 05:22 PM
Re: My Philco 16B - by Ron Ramirez - 09-25-2011, 05:53 PM
Re: My Philco 16B - by Arran - 09-25-2011, 08:11 PM
Re: My Philco 16B - by Marsupial - 09-25-2011, 10:08 PM
Re: My Philco 16B - by Doug Houston - 09-28-2011, 11:17 PM
Re: My Philco 16B - by codefox1 - 09-29-2011, 09:38 AM
Re: My Philco 16B - by Steve Davis - 09-29-2011, 10:47 PM
Re: My Philco 16B - by Arran - 09-30-2011, 01:40 AM
There are currently 9672 online users. [Complete List]
» 2 Member(s) | 9670 Guest(s)
