bulb numbers on my 19 anyone have an answer?
Yes - you have two options:
1. Ed "Blacksmith" sells reproduction gum rubber grommets of the same type as used originally to support and cushion tuning condensers.
2. Don Patterson in Georgia sells black rubber grommets that will put your tuning condenser at the correct height. These are stiffer than the original gum rubber, but will work.
"Blacksmith" has a website, Don doesn't:
http://www.renovatedradios.com/parts.html#rubber
dpatterson002 AT comcast DOT net
You can find these, and many other links to parts vendors, on my website:
http://www.philcoradio.com/resource.htm
Re: Philco 19 Question - by Ron Ramirez - 09-30-2011, 05:52 AM
Re: Philco 19 Question - by jerryhawthorne - 09-30-2011, 04:07 PM
Re: Philco 19 Question - by Ron Ramirez - 09-30-2011, 04:45 PM
Re: Philco 19 Question - by vinzer - 09-30-2011, 05:04 PM
Re: Philco 19 Question - by jerryhawthorne - 09-30-2011, 07:01 PM
Re: Philco 19 Question - by vinzer - 09-30-2011, 09:42 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6815 online users. [Complete List]
» 1 Member(s) | 6814 Guest(s)
