Philco 42-380 Tuner
Not sure what you are asking or familiar with this particular model. Think you are inquiring about manual tuning of the 540-1600 band. Normally there is a pushbutton labeled BC for manual tuning the 540-1600 band. Or could be on the bandswitch knob instead. You may have a bad switch contact involved with manual tuning.
Richard
Philco 42-380 Tuner - by Brad L - 09-29-2011, 03:12 PM
Re: Philco 42-380 Tuner - by rghines1 - 09-30-2011, 09:15 AM
Re: Philco 42-380 Tuner - by codefox1 - 09-30-2011, 10:52 AM
Re: Philco 42-380 Tuner - by Ron Ramirez - 09-30-2011, 11:20 AM
There are currently 10544 online users. [Complete List]
» 2 Member(s) | 10542 Guest(s)
