Philco 42-380 Tuner
Quick answer: No, the tuning knob will not have any effect on tuning when any of the preset AM buttons are depressed. You must push in the third button from the right, which should be labeled "B.C." (broadcast) to utilize manual tuning.
Now, if you have the B.C. button pushed in and it is not tuning across the band, then you definitely have a problem...I can't say that I've ever run into an issue like that before.
Philco 42-380 Tuner - by Brad L - 09-29-2011, 03:12 PM
Re: Philco 42-380 Tuner - by rghines1 - 09-30-2011, 09:15 AM
Re: Philco 42-380 Tuner - by codefox1 - 09-30-2011, 10:52 AM
Re: Philco 42-380 Tuner - by Ron Ramirez - 09-30-2011, 11:20 AM
There are currently 9676 online users. [Complete List]
» 1 Member(s) | 9675 Guest(s)
