cap question
OzRadio Wrote:I'm recapping my 40-180 and it has 2 .003 caps. On the siding they're rated at 1000 volts. All the others are typical 200 and 400 volts. Can these still be replaced by the 630V?
Ryan
Oz,
I'd check the schematic on this set. It looks like those you've pointed out are not origina, especially the voltage. I've never seen a Philco or any old radio that had original caps with a working voltage of greater than 600 or so volts.
I'd also say check the schematic to find out if this rating is legit. I guess an easy way to tell, look along the labeling of the cap. If it doesn't say Philco along the side, it's probably a replacement. This is OK, but I'd still confirm the original value, and voltage.
In the meantime I'd say that you can go with 630v if you're in a hurry. Icon_smile
GB
73 de,
Gary/N9VU
cap question - by OzRadio - 09-03-2006, 07:15 PM
Re: cap question - by n9vu - 09-04-2006, 08:06 AM
[No subject] - by Ron Ramirez - 09-19-2006, 09:04 AM
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6483 online users. [Complete List]
» 1 Member(s) | 6482 Guest(s)
