Philco 16B arch top
I was wondering if this chassis is the correct one for the "peaked top" 16B? This is not the same one I posted photos of in a previous post (5 band with a less peaked top) but the cabinet that has a top that is more pointed. It has 4 bands.
I know there are several 16B chassis, and they get put into wrong cabinets so I just want to make sure this is correct.
Philco 16B arch top - by thirtiesradio - 09-30-2011, 10:55 PM
Re: Philco 16B arch top - by Ron Ramirez - 09-30-2011, 11:09 PM
Re: Philco 16B arch top - by thirtiesradio - 09-30-2011, 11:14 PM
There are currently 9113 online users. [Complete List]
» 1 Member(s) | 9112 Guest(s)
