Technique for stuffing Philco sealed in plastic .
Kevin, thanks for that info. Looks like I need to take them out and pull off all the wires. Dang I hate that. PS how to I get to the Philco repair bench?
Jerry
Re: Technique for stuffing Philco sealed in plastic . - by jerryhawthorne - 10-01-2011, 10:36 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7767 online users. [Complete List]
» 2 Member(s) | 7765 Guest(s)
