Philco Model 38-2XX need some dimensions please
I don't own a 38-2, so I can't help you here.
...but, if you don't mind, and to satisfy my curiosity, may I ask why you are looking for these certain dimensions?
Re: Philco Model 38-2XX need some dimensions please - by Ron Ramirez - 10-03-2011, 06:45 PM
There are currently 10541 online users. [Complete List]
» 2 Member(s) | 10539 Guest(s)
