can you add a line in to a 40-190?
thanks for sending the schematic. why would they have a preset that's labeled phono/tv if it can't be used? is it possible to wire in, and tune it with the screws until it picks up the line in?
i know it sounds daffy, but my cd player in my car is like that - the radio has to be tuned to an fm station in order to pick up the cd player. so now i have this idea planted in my head, and that preset is labeled phono!
thanks again for your response!
nat
can you add a line in to a 40-190? - by Guest - 09-05-2006, 10:41 PM
[No subject] - by Bill Hutchinson - 09-07-2006, 05:30 PM
well, there's no input jack... - by Guest - 09-07-2006, 10:42 PM
[No subject] - by Terry Burns - 09-08-2006, 09:52 AM
so why the preset that's labeled 'phono'? - by Guest - 09-08-2006, 09:56 AM
[No subject] - by Chuck Schwark - 09-08-2006, 10:20 AM
[No subject] - by Guest - 09-08-2006, 11:44 AM
[No subject] - by Chuck Schwark - 09-08-2006, 01:35 PM
Philco 91 Tuning Condenser
