can you add a line in to a 40-190?
The PHONO button is for a wireless record changer, like Models 40-RP-1, 40-RP-2 or 40-RP-3 that "broadcast" the record to an unsed AM frequency for that pushbutton range.
can you add a line in to a 40-190? - by Guest - 09-05-2006, 10:41 PM
[No subject] - by Bill Hutchinson - 09-07-2006, 05:30 PM
well, there's no input jack... - by Guest - 09-07-2006, 10:42 PM
[No subject] - by Terry Burns - 09-08-2006, 09:52 AM
so why the preset that's labeled 'phono'? - by Guest - 09-08-2006, 09:56 AM
[No subject] - by Chuck Schwark - 09-08-2006, 10:20 AM
[No subject] - by Guest - 09-08-2006, 11:44 AM
[No subject] - by Chuck Schwark - 09-08-2006, 01:35 PM
Philco 91 Tuning Condenser
