Philco Model 38-2XX need some dimensions please
fair point on everything, I understand your passion for this hobby.. but the reality is that this old lady is hucking this radio in the garbage if I don't end up taking it..atleast i'm going to turn it into some good use (subjective). That said, I honestly am looking for a 38-3 or 38-7..any idea where I can get a rough cabinet? I'm in the Northeast.
thanks
Re: Philco Model 38-2XX need some dimensions please - by JROZ - 10-03-2011, 10:13 PM
There are currently 10400 online users. [Complete List]
» 2 Member(s) | 10398 Guest(s)
