finally beginning 118
TA Forbes Wrote:Hello, Glenn: dumb question, but is it bad?
Have you tried Play Things of the Past for your resistor?
Hey Tom,
The resistor is bottom center in the 2nd picture. It's supposed to be wirewound over the complete length. It's crumbled. I will try PTOTP, and if not then the link you sent is an option, I would like to keep it as original as possible.
Glenn
finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:12 PM
RE: finally beginning 118 - by Glenn Roberts - 06-16-2012, 03:56 PM
RE: finally beginning 118 - by Glenn Roberts - 06-17-2012, 08:18 PM
RE: finally beginning 118 - by TA Forbes - 06-17-2012, 11:11 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 01:26 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 06:57 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 07:13 PM
RE: finally beginning 118 - by Ron Ramirez - 06-20-2012, 07:42 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 08:07 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:43 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:46 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 12:51 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 01:02 PM
RE: finally beginning 118 - by 7estatdef - 06-21-2012, 04:05 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 04:18 PM
RE: finally beginning 118 - by Glenn Roberts - 06-23-2012, 08:43 PM
RE: finally beginning 118 - by Ron Ramirez - 06-24-2012, 07:29 AM
RE: finally beginning 118 - by TA Forbes - 06-24-2012, 12:29 PM
Re: finally beginning 118 - by ipwizard - 10-03-2011, 01:26 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:28 PM
Re: finally beginning 118 - by codefox1 - 10-03-2011, 02:22 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 02:26 PM
Re: finally beginning 118 - by TA Forbes - 10-03-2011, 10:57 PM
Re: finally beginning 118 - by Glenn Roberts - 10-04-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-06-2011, 09:03 PM
Re: finally beginning 118 - by Glenn Roberts - 10-07-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-08-2011, 01:08 AM
Re: finally beginning 118 - by Glenn Roberts - 10-08-2011, 04:17 AM
Re: finally beginning 118 - by Glenn Roberts - 10-12-2011, 06:10 PM
Re: finally beginning 118 - by PhilcoMike - 11-02-2011, 09:15 AM
Re: finally beginning 118 - by Glenn Roberts - 11-02-2011, 09:19 AM
Re: finally beginning 118 - by PhilcoMike - 11-03-2011, 08:19 AM
Re: finally beginning 118 - by Chuck Schwark - 11-03-2011, 01:54 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:22 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:41 PM
Re: finally beginning 118 - by PhilcoMike - 11-04-2011, 08:55 AM
Re: finally beginning 118 - by joejoe - 12-07-2011, 02:11 AM
Re: finally beginning 118 - by Glenn Roberts - 12-07-2011, 03:24 PM
Re: finally beginning 118 - by joejoe - 12-07-2011, 08:44 PM
Re: finally beginning 118 - by Glenn Roberts - 12-23-2011, 04:11 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 02:31 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 02:47 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 05:00 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 05:03 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 04:06 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 05:43 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 06:41 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 07:40 PM
The speaker table error?
Philco 70 antenna lead
