Philco 39-45 restoration: speaker wiring question and more
The mica caps in the pushbutton assemblies of those 1939-1942 Philcos are usually bad. Since they are only insulated with wax, they tend to absorb moisture over time.
370 pF is not a standard value any more, you can use 390 pF with no ill effects. Be sure you use new mica caps, or NP0 ceramics. Do not use regular ceramic caps as they will make the alignment of your pushbutton presets drift. Don't ask me how I know this...
Re: Philco 39-45 restoration: speaker wiring question and mo - by Ron Ramirez - 10-04-2011, 04:03 PM
The speaker table error?
Philco 70 antenna lead
