Pix of a Repro P-15-B5 BC battery for a Model 024 Siggy Gen
Dang! Awsome repro! Icon_eek
I assume the cardboard flap is not glued for replacement purposes? Local printer doing the die-cut and printing? or you??
Is the cardboard litho'ed? Or laser? Who is your source for the multi-pin sockets? Johnson? Keystone? Cambion?
Wow, so many questions - I'm not trying to do you in, just plain curious......I thought I was anal - great work there.
Now I have to restore one of my Mystery Controls so I can show it off with one of your battery packs!!
[No subject] - by Chuck Schwark - 10-21-2005, 06:39 PM
[No subject] - by batterymaker - 10-21-2005, 07:35 PM
