advice on cabnit refinish
Marsupial Wrote:I must say it is a LOT easier on smaller radios Icon_smile
Isn't that the truth.
Kelly you can create an account on Photobuket.com and upload you pics there, then just link to them on the Phorum. Copy the IMG links from photobucket and paste them into the forum window using the Img button on the post a reply screen.
-Keith
advice on cabnit refinish - by kelly - 09-24-2011, 12:26 PM
Re: advice on cabnit refinish - by Arran - 10-05-2011, 12:24 AM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 08:54 AM
Re: advice on cabnit refinish - by kelly - 10-05-2011, 11:50 AM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 01:18 PM
Re: advice on cabnit refinish - by ipwizard - 10-05-2011, 03:45 PM
Re: advice on cabnit refinish - by Marsupial - 10-05-2011, 10:23 PM
