Philco Model 95 Main Power X-Former needed
Pull the part number off the transformer (or service info) and see if Play Things of Past has one:
http://www.oldradioparts.com
Other alternative is another 95 junker chassis.
Philco Model 95 Main Power X-Former needed - by Guest - 09-14-2006, 11:45 AM
[No subject] - by Chuck Schwark - 09-14-2006, 12:55 PM
[No subject] - by Ron Ramirez - 09-16-2006, 10:36 PM
